Does anyone know if you can edit flight plans from a Mac or PC? I’ve found that building flight plans from the controller is a bit tough and it would be so much easier to do with a regular PC, Mac and Mouse. Thanks for any input.
I agree.Thank you very much. I will give that a shot. Surprised that DJI doesn’t offer this natively within the pilot 2 software.
That is exactly what I said and no correction is needed. Drones that use the DJI Fly App will use Virtual Sticks. The drones that use the DJI Go app will use what you're calling "on board"Correction - if the DRONE supports on-board waypoints, Litchi does. If not, then Virtual Sticks.
From the Litchi site - It's important to know that not all DJI drones support waypoint navigation. Additionally, there are two primary implementations of waypoint navigation: "on-board" (firmware-supported) or "virtual-stick commands" (VSC). On-board waypoints are loaded to the drone prior to flying the mission and are executed autonomously by the drone without the need for a constant connection between the controller and the drone. Virtual-stick waypoints commands are sent from the controller to the drone in real-time necessitating a constant connection between the controller and the drone. On-board waypoint missions tend to result in much smoother execution than virtual-stick waypoint missions.
Nope, several Fly app drones use on-board waypoints. Here is the listThat is exactly what I said and no correction is needed. Drones that use the DJI Fly App will use Virtual Sticks. The drones that use the DJI Go app will use what you're calling "on board"
Drone Release Date | Drone Model | Waypoint Support | SDK | Litchi Support |
Apr, 2015 | Phantom 3 (all) | On-board | MSDKv4 | Yes |
May, 2016 | Phantom 4 (all) | On-board | MSDKv4 | Yes |
Sep, 2016 | Mavic Pro | On-board | MSDKv4 | Yes |
Nov, 2016 | Inspire 1/2 | On-board | MSDKv4 | Yes |
May, 2017 | Spark | On-board | MSDKv4 | Yes |
Aug, 2017 | Mavic Pro Platinum | On-board | MSDKv4 | Yes |
Jan, 2018 | Air | On-board | MSDKv4 | Yes |
Aug, 2018 | Mavic 2 Pro/Zoom | On-board | MSDKv4 | Yes |
Oct, 2019 | Mini | VSC | MSDKv4 | Yes |
Apr, 2020 | Air 2 | VSC | MSDKv4 | Yes |
Nov, 2020 | Mini 2 | VSC | MSDKv4 | Yes |
Apr, 2021 | Air 2s | VSC | MSDKv4 | Yes |
Jun, 2021 | Mini SE | VSC | MSDKv4 | Yes |
Nov, 2021 | Mavic 3 | On-board | No | No |
May, 2022 | Mini 3 Pro | VSC | MSDKv5 (Android only) | Beta |
Sep, 2022 | Mavic 3 E/T/M | On-board | MSDKv5 (Android only) | Beta |
Nov, 2022 | Mavic 3 Classic | On-board | No | No |
Jan, 2023 | Mini 3 | VSC | MSDKv5 (Android only) | Beta |
Mar, 2023 | Mini 2 SE | No | No | No |
Apr, 2023 | Mavic 3 Pro | On-board | No | No |
Jul, 2023 | Air 3 | On-board | No | No |
Sep, 2023 | Mini 4 Pro | On-board | Q2 2024? | No |
As per post #7... no.So I can use Litchi with my Air 3?
Have you tried Flighthub 2?Does anyone know if you can edit flight plans from a Mac or PC? I’ve found that building flight plans from the controller is a bit tough and it would be so much easier to do with a regular PC, Mac and Mouse. Thanks for any input.
I am not aware of where to get Flighthub 2 for iPad, Mac or PC. Can you direct me to where is download is available?Have you tried Flighthub 2?
I didn’t realize this wasI am not aware of where to get Flighthub 2 for iPad, Mac or PC. Can you direct me to where is download is available?
I don’t realize this was a cloud based solution. Thanks for pointing this out, I will give it a try.I am not aware of where to get Flighthub 2 for iPad, Mac or PC. Can you direct me to where is download is available?
