Pilot error
AlanTheBeast
Montreal
1. Set landing spot too close to bushes.
2. Come in a bit hot...
3. ... in Sport mode
4. Avoid bushes with left thrust (bank)...
5. ... when right thrust (bank) was needed.
Broken prop
Snow packed up into gimbal
All seems well. Other than my ego. Member Frits witnessed this but had only kind thoughts ... well, kind words. His thoughts I don't know about!
Way over-exposed, I know... Beast and Frits below.
Unit is in food dehydrator at present. An initial test shows everything is fine. Just need to replace a prop. 4 - 8 hours at 50°C should remove the rest of the moisture.
S#*# HAPPENS. Glad that everything is OK
Thx. Unit is in food dehydrator @ 50°C for 8 hours. That should remove the rest of the moisture pretty well.
Marcos Machado
