- Joined
- Dec 21, 2017
- Messages
- 67
- Reactions
- 21
- Age
- 86
SC. is Smart ControllerTo cancel POI mode reenter the POI section and click the Exit button on the bottom left of the screen. What is SC?
You can also push the pause bottom at any time and the drone will stop what ever it is doing promptly
A sure way to cancel any operation in its tracks is to switch temporarily to sport mode. It is quick and works with any autonomous mode instantly. It also doesn't rely on you device connection, or risk a delay, since it is coming straight from the controller.
You can then recap your software at your leisure. Don't forget to switch back afterward.
A much better way to give you time to then access menus to cancel.
Much nicer as your bird heads to trees doing a dronie !!
Does pause actually cancel to whole POI or other quickshot function ?
And if not, do you push pause again and it resumes ?
Haven't ever tried that.
I believe it cancels everything but I’d have to check.
Im notIt actually won’t stop fixed wing mode so that’s why the pause buttton is your “panic” button because no matter the mode not matter the fuction no matter what the pause button will stop the drone in its tracks. Try flying full speed ahead in sport mode and then pressing the pause button. It will show you how quickly the pause button can stop you from full speed ahead
Im not sure you are correct on that. My research shows that sport and fixed wing mode are incompatible. But regardless, even if you’re correct, for all other modes the sport mode switch is the one method not device dependent. For those with slow/hesitant devices, it might very well be the difference between a collision with something or not. I know when using my android device, it would occasionally freeze, hesitate or disconnect, rendering the pause button useless.It actually won’t stop fixed wing mode so that’s why the pause buttton is your “panic” button because no matter the mode not matter the fuction no matter what the pause button will stop the drone in its tracks. Try flying full speed ahead in sport mode and then pressing the pause button. It will show you how quickly the pause button can stop you from full speed ahead
Concerning the pause at full forward speed, I have a question. Once while flying full forward I released the forward stick and accidentally pulled it back a bit. The drone came to a violent stop and reared up. It was over water just a couple of feet above and I really thought it was going swimming. The gimbal is a wonder as the the video didnt show any of the violent manoeuvre.
So my question is can this cause a flip and subsequent crash?
Im not
If nothing else, it would be good to have that in the back of your mind as a last resort.
