Points of Interest question
tropicalpests
cape coral, fl
When I create a box around my target how big of a box do I need? I t seems to drift to one side instead of keeping to the middle no matter the size box I'v created.
Any help would be greatly appreciated. Thanks !!
Are you referring to the box you’re drawing drifting or your AC?
It might have issues if there is little contrast between your POI and its background.
I've had the issue before. Thankfully, there are two methods to track your points of interest:
1. Using the vision system, drawing a box around an object
2. Using GPS system
This DJI vid explains both. Good luck!
The vision method of POI does not work so great, especially with large objects.
It doesn't find the exact center very well, so the orbit 'wobbles'.
I mostly use the GPS method. It creates a much better/smoother orbit.
It requires the additional step of flying directly above the POI first, but the result is usually worth it.
Reactions: dkuhne
peehead
