Porting flight path from DJI Fly over to a georeferenced mapping software like Avenza Maps
Dolmatian
Fairmont Hot Springs
Hello, I'm currently using a DJI Phantom 3 Pro for work, doing photography and GPS tracking, and would like to be able to port the flight path from the DJI Fly app over to a mapping software, like Avenza Maps.
Would there be a way to port the flight path information over to a different mapping software, import a georeferenced map over to DJI Fly, or would I have to use a different flight software to do the trick? I'm specifically looking to port the flight path and GPS locations of pictures to define boundaries on a georeferenced map.
Thanks in advance! And sorry if it's already been asked, kinda new to this 😛
Reactions: Jack in Dixie
You can get the flight path in gpx format using Airdata DL (pc version). Then I would use Global Mapper to import the gpx file & convert to just about format you like, e.g. pdf for use with Avenza & the appropriate underlay for area of interest. Alternatively you could dl kmz/kml file from airdata & import into Google earth, (maybe easier). Hope this answers.
RobertCNewman
