Pro Platinum - Installing Assistant 2
Turn11
Bullhead City, Arizona, USA
I am as new as they get, received Pro Platinum today, Android D/L DJI GO 4 and installed no problems.
D/L Assistant 2 and started the install. All was going well then the System Command prompt popped up and wanted to issue some commands via the system command prompt in what I assume was Chinese (no English). LOT surprised I said NO and it tried to issue two other commands or the same command two more times.
What are the commands? In this day and age I am just a little hesitant.
Larry
It's installing the USB drivers. Won't work without them.
Assuming you're on Windows?
Thank you Kilrah, I appreciate your prompt response.
I should have mentioned the OS. Windows 10 factory install with all updates. Since the days of DOS, I have not seen a program use (visibly) the command prompt during installation. (sheltered life).
Norton is happy, backup is current. time to get going
Larry
marcusjohn3684
