Prop gaurd options
Cant go wrong with the originals.
My Spark came with prop guards and I had to purchase a set for the MA2.
The guards obviously protect the props, but they also make the aircraft a bit easier to see when flying.
And if I may add... more prone to be affected by winds as they can act as sails, and if unlucky a lighter & weaker drone can blow away. So use them only close to ground in lighter winds.
Reactions: MA2 317
And if I may add :) . . . why use them at all, unless really needed ?
If flying close to walls, tree trunks etc, for normal cinematic flights, just go 'naked'.
They MAYBE good for this situation when you're a newbie and not quite sure, flying close to the ground and home point etc.
Good to just have anyway for the rare situation they can help.
As you are a pilot, you know how quickly the GF will get used to flying and build the confidence to know they won't make a lot of difference to most types of flying.
Analogdesigner
