Propeller guard
Reactions: eaglesurfing
I have had 2 people here at contrary things. One does a good fit other days it would need to get forced on because the shadow at the front motors isn't proper fit.
Hmm.
There's a 1mm height difference between the JP version of the Mini2 and standard version of the mini 2.
The original Mini is 55mm tall (unfolded), the Japanese version of the Mini and Mini 2 are also 55mm tall. The standard version of the Mini 2 is 56mm tall.
The Mini 2 (non-JP) is also 1mm wider unfolded than the Mini (arms go out 0.5mm further). But is identical (289mm) with the props factored in.
So the parts that the prop guard holds onto has expanded by a millimeter.
Some people say it fits no problem other say no. Weird
I wonder if the prop guards have a very slight variation in manufacturing since they are injection molded, and on the standard side they could still fit and bend a little without impacting with the props, but add half a milimeter out of margin on some of them and might not fit that well.
gomezstatiq
