Some time ago I posted an explanation of the difference between "dumb" and "stupid". Yesterday I gave a personal demonstration of BOTH definitions.
It actual begins with WISE (wisdom). During my pre-flight inspection (very wise of me), I discovered a chip in one of my props.
I quickly removed the damaged prop and replaced it with a brand new OEM prop. (still being very wise).
Being an expert (and incredibly humble) flyer, I assumed that I'd properly installed the prop. (That was dumb!)
Then, even though the thought crossed my mind to do so, I powered up the controller and the bird without checking things over, and took off (That was STUPID!)
The bird launched and I hovered in place at about 10 feet for 15 seconds or so as is my normal pre-flight routine (back to wise).
Everything appeared clean and green, so I hit the left stick to show off a rapid climb to a friend I was trying to impress....
...and all hell broke loose! My bird climbed to about 15 feet, then went into a violent, spinning crash!
The new propeller I'd installed was GONE! I was very lucky in that the only damage to my bird was a small repair to the gimbal and a cracked from leg.
QUESTION FOR ONE OF THE "ENGINEER-TYPES" ON THIS FORUM: At 600 RPMs, how far away from the take-off point might a propeller fly without the drone connected to it? LOL!
