I just installed the Master Air Screw stealth props.
These are my personal findings as follows:
The MAS props are no doubt thinner then DJI's props.
The MAS props are a bit longer, you will realize this when the drone is folded for storage.
I opted to use the original prop screws for no other reason, just my decision.
The MAS screwdriver leaves a little bit to be desired. After using the screwdriver (MAS) I thought it didn't fit the screw heads quite well, so I opted to use the DJI driver provided with my MM2 drone. Better fit.
Then again, if I used the MAS driver on the MAS screws it probably would have fit ok, I didn't try it.
I opted not to use Loctite since I saw none on the original screws when removed.
To save your hands, (especial if you have big hands) I found it best to fit a 7mm socket and ratchet wrench on the end of the DJI driver. The socket fits tight, be sure to seat it in the socket.
Using the driver this way, it's much easier to remove and tighten the prop screws.
The props I chose are black.
Weather the props will provide a quitter flight and longer flight time, as claimed, I can't tell as night here has fallen.
That's another story.
I hope this will help those who are interested or thinking about purchasing the stealth props.
