The only SDK available for the Mavic Mini is DJI's Mobile SDK, where you typically don't see much python being used.there is a way to program mavic mini with python? for DML ro DRL algoritim
i mean deep machine learning and deep reinforcement learningThe only SDK available for the Mavic Mini is DJI's Mobile SDK, where you typically don't see much python being used.
What do you mean by DML or DRL? Those initials can have wildly different meanings by context. Together, they usually stand for Data Manipulation Language and Data Retrieval Language, which seems out of place for a drone and are not algorithms.
The Tello drone has a simple REST API exposed over UDP. You can access that with python.
Then you are looking at DJI's Windows SDK, which doesn't support the Mini. The Mobile SDK would be the second option if you use the ML capabilities on iOS. Trying to use python on iOS would be like trying to force a square peg into a round hole.i mean deep machine learning and deep reinforcement learning
