I just got the Moveiro 300 glasses. I thought they were working fine, until I waved at myself--32 second lag!!
I called Epson for tech help. I was helped to upgrade the Epson software. While still on the phone with Epson, I tested and the lag was about 1/2 second.
However-- the lag is back! to 25-30 seconds!! All software is updated . I recalibrated everything.
I think I'm going to have to return this item. It's just too frustrating.
I'm not so sure the new DJI software is so compatible with the RC1B transmitter.
I would do a reset from the settings menu
What version of DJI Go4 are you using, did you download this from the
Moverio store or have you sideloaded it ?
I would only load the DJI Go4 app and no other apps
Have you turned off bluetooth, caching to the device, histogram, over exposure warning, focus peaking etc. ?
What cable are you using, hopefully not some cheap stuff ?
I believe latency and pixelation is improved if you select a custom frequency and the 10mhz bandwidth.
You can tell the amount of latency by the transmission rate at the bottom of the HD screen, should be up around 20mbps
In the DJI Go4 app
1) Select the "..." in the top right hand of the flight screen to access the settings menu
2) go to the HD menu
3) Select "Custom" it should turn blue, and hit the blue "transmission state" to open the frequency graphic
4) Slide the frequency box from side to side to select the desired channel
5) Below the frequency graphic, you will see "bandwidth allocation" , select "10mhz" for high interference situations, then it will turn blue
6) Also play around with "Image Transmission Mode" try the different modes, I think "smooth" is the best, but their are limitations in frame rate etc. with selecting it
