Quick Transfer
Hornet600
UK
Anybody else find they can’t upload videos using Quick Transfer to the iPad Air 2, the video was taken in 1080p@30fps. The error I get is, unable to download H.265 video, Connect to computer to export.
Guys my bad. I must of accidentally changed the coding format in the camera settings to H. 265, I’ve changed it back to H.264 and all‘s good now.
Any time you use the higher frame rate (like 4k/60) it will switch to H.265. It will not switch back when you change your setting back to a lesser frame rate. You have to go in and change it back manually. At least it does on the Air 2 so I would assume it does the same on the other models.
Reactions: Hornet600
Nuno Almeida
