RC Geek Visor & Range extender
RallySoob
Not sure on performance yet but the sun visor is very nice tight fitting design with the added velcro idea works great, they did a better job than dji as far as that goes but i like the finish of dji visor better. I'll use this one tho i can tell already
The range extenders actually focuses your antenna's projection to a stronger yet much more narrow beam so as I understand it the controller must be aimed at the aircraft to benefit from this device otherwise it will cause you to lose range. "You must keep the narrow beam on the mavic at all times " since i have not tested it yet I can not verify but I will know by tomorrow morning;)
It seems the range extender may be useful in only certain situations but useful none the less. Until its confirmed garbage i keep it in my case
cjd54
