- Joined
- Jan 3, 2018
- Messages
- 106
- Reactions
- 40
- Age
- 45
I have a battery that I put on a DJI quad hub with two other batteries, and when it cycles around to that battery the led light on the hub turns red and the battery does not charge. Battery has half a charge and when you hit the button it will still show you half a charge left; but it keeps doing that same thing with a red led alert. I put the battery on a quick charger that isn’t DJI (It’s Smatree) and the Smatree charger is always loud when it charges, and you can hear it charge loudly for about 7 seconds and stop. Then it will shut off after the 7 seconds of charging and the battery shuts off, then it will kick back on charging loudly for about 7 seconds again, and continue that routine over and over. After about 6 cycles of that it will kick off for a while-like 20 seconds and then try again, going through the cycle of charging 7 seconds over and over again…. Does anyone think that the battery is ruined? Is it safe to use? Is there a way to reset the battery since its an intelligent battery? I can’t believe there isn’t more threads on here about this issue…. Thank you guys for any advice…
