Reproduce or equivalent dji mavic 2 pro video transmitter
abbas
Pak
Hello is there any information on the dji mavic 2 pro's video transmission system ?
Actually we need to develop POC for video transmission system and my boss is insisting on using 2 pro as it is for vtx we are unable to find any digital VTX with usb video out I know this is bad and expensive idea but i have no option that is why i am asking for community's opinion.
Should we go with a strip down dji wiht only camera or is there any alternative digital vtx with usb video out ?
You can find the transmitter units online (DJI or E-BAY)
O3 PRO weighs in 2nd hand at about £899.
I'm sure you can find the O2 version (Mavic 2 Pro/Zoom) a lot cheaper.
Specifications (O3 PRO)
Weight
DJI Video Transmitter: Approx. 350 g (excluding antennas)
DJI High-Bright Remote Monitor: Approx. 727 g (excluding antennas)
DJI Video Receiver: Approx. 350 g (excluding antennas)
DJI Video Transmitter: 127×87×26 mm (L×W×H, excluding antennas)
DJI High-Bright Remote Monitor: 213×135×51 mm (L×W×H, excluding antennas)
DJI Video Receiver: 127×87×26 mm (L×W×H, excluding antennas)
Operating Frequency
When using the DJI Video Transmitter with the DJI High-Bright Remote Monitor:
Non-DFS Frequency Band:
2.400-2.484 GHz
5.150-5.250 GHz
5.725-5.850 GHz
DFS Frequency Band:
5.250-5.350 GHz
5.470-5.600 GHz
5.650-5.725 GHz
When using the DJI Video Transmitter with the DJI Video Receiver:
2.4000-2.4835 GHz
5.150-5.250 GHz
5.725-5.850 GHz
DFS Frequency Band:
5.250-5.350 GHz
5.470-5.725 GHz
In some countries and regions, the 5.1/5.2/5.8 GHz frequencies are prohibited, or the 5.1/5.2 GHz frequencies are only allowed for indoor use. Check local laws and regulations for more information. 5.600-5.650 GHz is not used.
Transmitter Power (EIRP)
2.400-2.484 GHz:
<33 dBm (FCC)
<20 dBm (SRRC/CE/MIC)
5.150-5.250 GHz:
<23 dBm (FCC/SRRC/MIC)
5.250-5.350 GHz:
<30 dBm (FCC)
<23 dBm (SRRC/MIC)
5.470-5.600 GHz, 5.650-5.725 GHz:
<30 dBm (FCC)
<23 dBm (CE/MIC)
5.725-5.850 GHz:
<33 dBm (FCC/SRRC)
<14 dBm (CE)
2.4000-2.4835 GHz:
<33 dBm (FCC)
5.725-5.850 GHz:
<33 dBm (FCC)
<14 dBm (CE)
<23 dBm (SRRC)
Max Bandwidth
40 MHz
Max Bitrate
40 Mbps
Power Consumption
DJI Video Transmitter: 11 W
DJI Video Receiver: 9 W
Power Supply Voltage
6 to 18 V
Output Voltage
Power output port: 6 to 18 V
Operating Time
DJI Video Transmitter: 3 hours 40 minutes
Measured at room temperature (25°C/77°F) with a fully charged WB37 Intelligent Battery.
DJI High-Bright Remote Monitor: 2 hours
DJI Video Receiver: 3 hours 50 minutes
Tested at room temperature (25°C/77°F) when powered by a fully charged WB37 Intelligent Battery and used with the DJI Video Transmitter.
Input Video Format
1080p: 23.98/24/25/29.97/30/50/59.94/60fps
720p: 50/59.94/60fps
Output Video Format
Only the DJI Video Transmitter supports video input at fractional frame rates and loop-out. The DJI High-Bright Remote Monitor and DJI Remote Monitor Expansion Plate do not support video display or output at fractional frame rates.
When using the Ronin 4D Video Transmitter with the DJI Video Receiver:
1080p: 24/25/30/50/60fps
Input Audio Format
SDI embedded, HDMI embedded
Output Audio Format
PCM
Video Transmission System
O3 Pro
Video Transmission Latency
70 ms
Measured when shooting 1080p/60fps video.
Video Coding Format
H.264
Max Transmission Distance
6 km (FCC)
4 km (CE/SRRC/MIC)
Measured in open environments without obstructions or interference.
Operating Temperature
-10° to 45° C (14° to 113° F)
When using the WB37 Intelligent Battery, the recommended operating temperature is above 0° C (32° F). Take measures to keep the battery warm when using in temperatures below 0° C (32° F).
Mirror Control Mode Supported Camera Models
ZV1/A7 III/A7S III/A7M III/A7R III/A7R IV/A7 IV/FX3/A7S II/A6600/A6400 and all Sony cameras that support BRAVIA (HDMI control).
JefScot
