P photo2be Well-Known Member Joined Nov 9, 2020 Messages 353 Reactions 174 Age 56 Location Stockholm Swedem Feb 4, 2021 #1 Hi. is it normal that I have to set RTH height and max distance everytime I power on the Mini? Does it not saves my previous settings?
D Deleted member 103366 Guest Feb 4, 2021 #2 That is abnormal, though perhaps not a bad thing as at least it means you have seen what they are set to at the start of every flight. As an after thought.....Unless it stems from something going wrong which might get worse. Last edited by a moderator: Feb 4, 2021
slup Well-Known Member Joined Oct 18, 2019 Messages 4,958 Reactions 10,960 Age 57 Location Sweden Feb 4, 2021 #3 Why do you think you must set them every time ... are the values reverting to some defaults or what's happening?
P photo2be Well-Known Member Joined Nov 9, 2020 Messages 353 Reactions 174 Age 56 Location Stockholm Swedem Feb 4, 2021 #4 PhiliusFoggg said: That is abnormal, though perhaps not a bad thing as at least it means you have seen what they are set to. Click to expand... Have done slup said: Why do you think you must set them every time ... are the values reverting to some defaults or what's happening? Click to expand... I think I solved the problem. When I "clean" the cash in the Ipad (and FLY APP) it seems to kind of go back to default values. Reactions: Deleted member 103366
