Returning Pilot in Colorado
Good day,
I found this forum while researching my new Mini 4k. I previously had a Phantom 3, but sold it several years ago during a move and somehow forgot to replace it until this week.
I figured I might as well sign up since I was lurking around anyway.
-Will
A big welcome to the forum from the UK!
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Colorado, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to the User Manual offered by DJI for the Mini 4K
Fly On and Fly Safe…
Thanks for your detailed response. I will be reading this more than once and taking your advice.
Cheers!
-Will
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members who are willing to help you with any questions you might have. Search the forum using keywords and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response!
Fly safe, enjoy and stay safe!
Dispatcher
