RM510B with Mavic Pro 3 ?
Oke I made so progress.
I downloaded firmware for the RM510B (latest version) from the following website
Dank Drone Downloader - Web App
Then I used the the old Drone-hack application (1.37) to upload the firmware to the controller.
After installation you'll have the controller with Firefox. I installed the DJI Fly app from the DJI website.
You can then open the App and link the drone, all works fine. Only problem I need to solve is a known problem searching on the internet. When you switch off the controller and start again, the DJI Fly app is gone. You need to re-install it again. I think this has to do with the RM510B version.
So i'm nearly there , only need to fix this issue....
I've got a second hand RM510B enterprise.
It came with a Ukrainian/Russian hack pre-installed for switching between between apps, but like you had to keep re-installing DJI fly so wiped that off the remote.
The fix is on Drone hacks. Use there V2 hack tool for RC Pro remotes not V1.
Your be able to multiboot like before & you wont have to keep re-installing the latest DJI fly.
Works with all FW versions too.
I also applied a hack to get Litchi working without licence verification because amazons servers will go down forever.
To do that you need
Litchi v4.28.0-a .apk A=Amazon app store version, closes down october 2025
Lucky Patcher, to remove license verification
Speech Recognition & Synthesis TTS.apks so you get vocal synthisis feedback
Total commander - android version or simular that can handle split apks files.
Apk(s) back up tool
Note*
Litchi v4.28.0-g=Google Apps, wont work on these remotes without Gapps
Update!
Litchi_4.28.0-l works on RM510 & B as long as you've paid & added your credentials..
Litchi will be handling licences via there own servers.
I paid too for Litchi v4.28.0-a & g but at the time needed to remove licence verification due to Amazons decision to permanently shut down there servers and at the time Litchi_4.28.0-l was not Available.
Still, it is nice to not have to add names & passwords for something you purchased anyway right..
Reactions: newaltitudephoto
To do that you need
Apk(s) back up tool
Note*
Update!
Yes I have the RM 510-B also , I was able to use the drone hacker website to flash a firmware that allows you to run pilot app and Dji fly on the same remote. Works flawless and I am using Litchi. Process was about 15 mins and the cost was $90 bucks
jwright17
