It will try, but it's always better to set an appropriate height to clear any obstacles on your RTH path rather than hoping obstacle avoidance will do what you want.
Thanks for info. Altitude is our friend but there are obstacles higher than 400' AGL. Will avoid flying in those areas.I'm flying my M2P in a restricted area, max height 50m. The topography is up and down, put in new battery at the lowest point, flew a long left turn at max height 50m, over a low hill with trees, lost visibility of the drone, because of the treetops, should have seen it after a few seconds, but no.
What happened?
The top of the trees is about 55 m, my 50 m limit, takes my drone. Lesson learned.
PS.
Found the drone unharmed on the ground.
Never use OA.
DS.
If I understand correctly, you set the operating ceiling to 50m. The aircraft treats that as a hard limit and will not exceed it, regardless of OA needs.I'm flying my M2P in a restricted area, max height 50m. The topography is up and down, put in new battery at the lowest point, flew a long left turn at max height 50m, over a low hill with trees, lost visibility of the drone, because of the treetops, should have seen it after a few seconds, but no.
What happened?
PS.
Never use OA.
DS.
On the other hand, in my opinion the height limt should never be set above 400ft unless you are flying up hills etc. because it is a safety risk. Especially with the God awful setting sliders in the FLY app.In my opinion the height and range limits should always be set to maximum (500m and unlimited) for exactly the case you encountered.
How? Just don't fly over 400ft... it's right there in the display. Flying at 420ft is not meaningfully more dangerous than 400ft.On the other hand, in my opinion the height limt should never be set above 400ft unless you are flying up hills etc. because it is a safety risk.
Made the mistake once with my Air 2 getting too close and losing signal near a 1100 ft building. Didn't have the RTH set high enough and the building was too wide, so it just hovered until I moved and regained signal.
Thanks for this input. Was the RTH set on 'bypass'?Made the mistake once with my Air 2 getting too close and losing signal near a 1100 ft building. Didn't have the RTH set high enough and the building was too wide, so it just hovered until I moved and regained signal.
Have kommersial flight in to Stockholm Arland at ca 650m, I take no risk, 50m will be my max.If I understand correctly, you set the operating ceiling to 50m. The aircraft treats that as a hard limit and will not exceed it, regardless of OA needs.
In my opinion the height and range limits should always be set to maximum (500m and unlimited) for exactly the case you encountered. Where there is a flight ceiling, that should be managed by the pilot. You are arguably creating a safety risk by limiting your freedom of movement, an emergency may require you to break these limits to avoid injury or property damage to a third party.
maintaining an altitude ceiling while flying is so easy with these drones I almost want to say that someone who can't shouldn't be in the air in the first place.
