Hi I have this issue that happened couple if times. In this video you can see that after RTH was initiated, the drone flies back to home but as you can see it paused for like 6 to 8 seconds then continue flying back home. It happened two times in this flight.
I did not pressed any controls aside from gimbal tilt when it pauses the RTH. Did this happened to you as well? I've got no errors. OA is turned on as well. I am not sure if is is the sun but I did not see any elevation change if it is avoiding something.
Flight Log from AIR Data and Phantom Help :
You can check the 2:30 and 4:40
I am now uploading the video, will update this post once uploaded.
DJI Flight Log Viewer | Phantom Help
Upload and view DJI Phantom, Mavic, and Spark flight logs online
www.phantomhelp.com
