RTH, then went above 400 ft?
looopson
I had a rather interesting flight yesterday. My Mavic Pro was at a height of about 370 FT and a distance of only about 110 FT from me when I hit the RTH button. My failsafe/RTH altitude was set at 30M which equates to about 100 FT or so. I am new to flying this, but my understanding is that the drone would turn accordingly first towards the homepoint, then cruise at an altitude of 370 FT to my home point (since I was well above the RTH altitude). It would then lower.
Instead, my drone quickly went UP to about 460 ft, well above the 120M limit I have set in the app. Interestingly enough, the warning that it had reached the maximum height did not go off. I cancelled RTH and brought it down to a lower height of about 250FT, I then hit the RTH again and it once again, went UP instead of down... I was concerned at that time because it was getting quite windy and I could hear the drone struggling.
The only thing I can think that caused this was when the drone turned back towards the home point, the Sun was in the West, closely to setting. Is it possible that the drone detected the Sun as an object and went up in an attempt to avoid it? Even above the maximum altitude allowed?
I also noticed when I tried to bring it home manually, the drone constantly stopped after going forward and said "BRAKING NOW! RETURN STICKS TO MIDPOINT". This is why I'm lead to believe that the Sun was what was creating all of this confusion with the drone because it probably had that in its view. I still don't understand why it would go up, exceeding the 400FT limit in my settings though. Does my rationalization sound valid? If the Sun is causing the forward sensors to disable the drone from certain functions, maybe in the evening conditions, I should consider turning that feature off?
Reactions: bertram33
That braking message is displayed when the front sensors detect an obstacle. If that happens again, you can resolve the problem by disabling obstacle avoidance in DJI GO.
Thanks
Do you believe that obstacle avoidance was also causing the drone to go up and up when I hit RTH because it saw the Sun?
Yes.
Reactions: looopson
Same thing happened to me. Definitely climbing to avoid the "obstacle" it's seeing in the sun.
Turn off front obstable avoidance when the sun is low, or just turn it off altogether unless you're flying somewhere that you might need it.
You can disable obstacle avoidance in the following section of DJI GO:
In this scenario, you should just fly around the sun, like in a semi circle, then fly it back manually!
One should only use RTH in emergencies!
I always fly back manually. You could always use home lock as well.
Reactions: scooot
Hell... I use it when I don't feel like flying it back long distance. I just sit back, relax and enjoy the view.[emoji38]
Or just turn off rth obstacle avoidance leaving in flight OA on.
Personally I wouldn't want to lose manual control, which is what happened to me. I wasn't trying to bring the Mavic home....I was just flying around a park with the sun behind my back. I started trying to fly back towards me manually when the Mavic would stop abruptly and refuse to come back. This happened over and over. I then hit RTH and it started to climb above 400ft. I regained control and started to zigzag home. Took forever.
No more forward obstacle avoidance for me.
Personal choice but for me it's OA on in flight and off in rth.
You could leave the OA on if you desire and always switch to sport mode which will disable the OA if you encounter the pre mentioned scenario.
Reactions: dcpmark
GREAT point about switching to Sport Mode as a fix for this problem.
Reactions: scooot
Just fly sideways manually? o_O
Reactions: dcpmark
Ha! Another great solution. Wouldn't have occurred to a panicking noob like me. :D
I actually didnt KNOW what was causing the problem at the time it happened....the reports of this issue were JUST starting when it happened to me, and I hadn't seen anyone post about it at that time.
Gavthistle
