Screen Caution notification
Duckydiver
All right it's getting colder out there and I've noticed a couple of things running across my screen On the RC It's been only when it's cold
It says stick ENI 2
And
manual R T H
It says stick ENI 2
And
manual R T H
Howdy from Wyoming Duckydiver, welcome to the community, plenty of fine folk and excellent information here. I am not able to help with your error codes but I am sure someone will be along who can assist.
Welcome to Mavic Pilots! :)
Here's a known list of remote controller messages from the Mavic manual:
Just a reminder it is ENI 2
And then the other is manual RTH
Are you sure you don't mean "STICK EMI2+MANUAL RTH"?
Reactions: OzoneVibe
Make sure there are no other electronic devices near your remote controller and take your Mavic for another flight to see if you can reproduce that issue.
If you see that message again, then try calibrating the remote controller in DJI GO like this:
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching .:)
If your device you are using in your controller is an iPad then please rotate the ipad 180°
Some ipads such as ipad 4 has a magnet in one edge which is used with a case to magneticly turn on off ipad.
When you insert ipad into controller you may insert with magnet close to your stick which just happens to be stick 2 which causes the interfernce.
By rotating ipad 180° it puts magnet at bottom and far enough away not to interfere with your hall effect gimbal sticks.
Hope this helps.
Cool thanks
To the guy to reply to the 2 mavics that he purchased And to iPhone
Maybe he needs to take it off of wifey 1st lol
I got the same error stick emi2 manual return to home.... same tablet I always use wi-fi off, location on. and also the tablet gave me a warning that it was too cold to charge... but it is beautiful 7.8 degrees and windy,,,, just wanted to do a quick test flight to test out my new ND filters.... neewer brand they worked well and were less than a gram each.... but would severe cold affect electronics like that?
TocSin
