screwdriver for prop screw
John Mac
Northern Kentucky
I attempted to change out a set of props (nicked) just now, and the Phillips screwdriver sent with the Mini 4 Pro seemed improperly sized for the prop screws. I was just spinning in the screws and concerned I would damage the screws and be unable to remove them.
Tried a different size Phillips screwdriver (marked PH00) and it worked fine. Screwdriver that came with the drone went into the garbage. For comparison, the screwdriver that came with he Mini 4 Pro is on top. The screwdriver that actually works is below.
Reactions: Cafguy
It looks like, not only is the PH00 bigger but the top one appears to be JIS
I can't say it is but the taper is more pointed than the PH00
ya those little DJI screwdrivers are garbage.
JoettaReady
