SD Card in Drone vs In My Tripltek 9
wmrichar
Orange County, CA
I am new to drones. I just recently bought the DJI Air 3 Fly More Combo with the RC-N2. I am using a Tripltek 9 Pro with the controller. I have not yet flown the drone.
I thought I read somewhere, you can go without an SD card in the drone itself and just use the SD card in the Tripltek tablet to save video and photos to the tablet's SD card. Is that possible? If so, will the quality be the same?
Other than that question, I am ready to start flying. I've got the TRUST certificate and I've registered the drone with the FAA. I also have all necessary apps and firmware updates.
Thanks!
The drone needs to have an SD card to record images and video in 4K. You can record the screen on the Tripltek at the same time you are flying your drone, although, you will be recording what you see on the screen, including the telemetry and all other information on the screen.
Reactions: wmrichar
Perfect. Thank you very much for the info. That answered my question.
You can put a card in the controller, but there's no real need to.
The full-size images and video files will always be saved to the card in the drone.
There isn't enough bandwith in the controller signal to save full-size image and video files and fly the drone.
Anything saved to the controller will be much reduced cache images.
Reactions: wmrichar
Unless you want to transfer the files to the Tripletek for viewing on it.
The Air 3 has 8 GB internal storage. This is enough for many images but will fill up quickly with video. The Air 3 can use a SD card up to 512 GB. I keep several SD Cards on hand and use separate cards for each job. As mentioned, you can transfer the files to the Tripltek for viewing but I never bother doing that. I wait to transfer them to an external drive on my PC.
Reactions: wmrichar
JonSeale
