Signal Interuption Message
The "flat faces" of the antenna should be facing the AC....
If you had the tips "pointing" to the AC, you would be getting diminished signal to the AC and more suseptable to interferance.
This is exactly why you had the warning, if you had the tips pointed at the aircraft??
Follow @Flycaster 's antenna configuration with the flats of the antenna facing the aircraft.
The antennas on the craft are flat circuit boards in the front legs, they are angled to try to make them parallel to Remote Controller
It is not a DJI problem. It is flagging legitimate interference every time I have encountered it. I used my Mac laptop with a WiFi analysis package and could clearly see many WiFi networks broadcasting away. The laws of physics prevent DJI from eliminating these sources either with hardware or software.
The warning is for you, the pilot In charge, to respond accordingly.
To clarify, .510 is the latest FIRMWARE version for M2Z/P.
Latest Go 4 app version is 4.3.25 which can be used on all consumer Mavics.
thebulldog22
