Single straight white line is very annoying.
Bearcat69
Connecticut USA
So I recently purchased a dji mini pro 4 to complement my hiking. I noticed that their is a white line in my videos and photos at is sometimes their and depending on the brightness of the subject seem to go away on darker images. It sometimes flickers and dosen't completely traverse the entire screen. It does it while recording and not recording. When I zoom out it goes to the side and exits the screen. Then returns case i zoom back in. I will atach photo. Please help me go in the right direction. dji_fly_20250424_175022_0023_1745539110329_aeb.jpg
  • Wow
Reactions: LoudThunder
Hello from the Crossroads of America Bearcat69.
There's plenty of pilots here that may help with past experiences dealing with image quality.
I unfortunately don't have that knowledge.
Welcome to the Forum. :cool:
First off, as you wrote, it's a new drone, and whether it's under Care Refresh or not, it would be a warranty issue and not something you would burn up a Care Refresh replacement…
If you want to mess with trying to figure it out is up to you, but I would not bother, I'd take it back to the place of purchase and see if they will replace it, free of charge, otherwise, contact DJI Support…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Connecticut , there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Glitch in the Matrix, Or a camera on a Drone that needs to be returned.
airtoku
