Smart Controller will support Mini 2 soon
Right after my DJI Smart Controller (Black thing with a bright screen built-in), upgraded itself to be compatible with Mavic Air 2, it stopped responding when i plug it into PC running DJI Assistant 2. Often the USB animation would work, but nothing. I watched the connection happen on Device Manager (Windows 10).. also nothing. Is this a thing for you guys too? I hope the thing knows how to update itself by Wi-Fi once the Mini 2 firmware is released!
you need to check your assistant 2 version and be sure it the most current. it should be V2.0.14
Hi, thanks for your reply. Yes the DJI Assistant 2 is V2.0.14, however Windows Device Manager reports the SC connection as UNKNOWN USB DEVICE (Port Reset Failed)
Hi TruGreen,
I've resolved the issue using the cheap USB cable! Turns out the cabling that came with DJI Smart Controller was the issue. :(
I think you have to use Dji assistant 2 for Mavic now.
coregambit
