After doing a quick read of the manual, these are my notes and comments......
Sport Mode Braking Distances
"It is recommended to discharge the Intelligent Flight Batteries to 30% or lower. This can be done by flying the aircraft outdoors until there is less than 30% charge left."
Transmission signal radiates from top of phone holder/antenna. Point the two phone holder rods at the MA2 for optimal signal strength.
Includes the Fly app manual as well.
CAUTION: Pressing both joysticks to the bottom inner or outer corners (typical motor startup command) will STOP the motors in mid-flight.
Recommended microSD Cards:
Testing Scenarios for someone to try:
Active Track 3.0 maximum tracking speeds
- The maximum speed and braking distance of the aircraft significantly increase in Sport mode. A minimum braking distance of 30 m is required in windless conditions.
- Descent speed significantly increases in Sport mode. A minimum braking distance of 10 m is required in windless conditions (watch out for this one you don't want to smash your MA2 into the ground)
SanDisk Extreme PRO 64GB U3 V30 A2 microSDXC
SanDisk High Endurance 64GB U3 V30 microSDXC
SanDisk Extreme 64GB U3 64GB V30 A2 microSDXC
SanDisk Extreme 128GB U3 V30 A2 microSDXC
SanDisk Extreme 256GB U3 A2 microSDXC
Lexar 667x 64GB U3 V30 A2 microSDXC
Lexar High-Endurance 64GB U3 V30 microSDXC
Samsung EVO Plus (Yellow) 64GB U3 V30 microSDXC
Samsung EVO Plus (Red) 64GB U3 microSDXC
Samsung EVO Plus 128GB U3 microSDXC
Samsung EVO Plus 256GB U3 microSDXC
Kingston V30 128GB U3 microSDXC
Netac 256GB U3 A1 microSDXC
- Trace: 8 m/s (17.9 mph) when in Normal and Tripod and 19 m/s (42.5 mph) in Sport mode.
- Parallel (no obstacle avoidance for all modes): 12 m/s (26.8 mph) when in Normal and Tripod and 19 m/s in Sport mode.
