Sports mode yaw movements have gone crazy
Ripper7620
My MPP flies great in P-mode, but in Sport Mode, when I try to gently work into a graceful turn, it keeps on turning even after I let go of the stick, and it’s impossible to control. I’m guessing my settings are inappropriate, so I’m including screenshots of my current settings. Thank you in advance for any insight you can provide.IMG_0106.JPGIMG_0107.JPGIMG_0108.JPG
See if changing your Gain settings to 90% helps.
I do not fly in sport mode because of the jerky movements (sensitive sticks). Instead, I turned off the forward sensors. It gives more speed without changing the stick characteristics.
Thank you for the reply, I appreciate it. I figured I had something set too low, because when I did on my P4P, it made the AC uncontrollable.
i found these videos quite helpful in setting my MPP up out of the box
Reactions: Ripper7620
faridudinmuhammad
