Stick error. ?
I could not find this question in the look up section but does anybody know what stick error means. My drone is drifting all over and does not return the home anywhere close to where it supposed to. The controller just says stick error
Can you try & update the DJI GPS fly safe database? it should pop up when you first connect to the DJI go app. That Should solve this problem sounds like your gps is out of whack
Lmk if that does the trick
I was about to ask what mode!? GPS? Or Atti... I would like to assume being In the park, the GPS would pick up. When you did the calibrations, you were in the park!? And by chance do you have the Polar pro app!? It will let you know magnetic interference or K factor for your area. I’m guessing it’s not that.. but... I’m also guessing if you have a high k then it would be off.
Come to think of it I had received an occasional stick here but it quickly went away and I never thought much of it. New development, I just got done with DJ I on the phone they told me to do and A compass calibration and imu Calibration and then try it I did all that and I tried it end it behaves so erratically 20 feet up in the air it scared me to death it took all I could do to crash it into my roof just to get it down. Very very scary. Now I’m sending it to DJI, There are a few local drone repair shops but I’m not sure I have confidence in them They say most of it is still under warranty it’s been seven months with both my care refresh drones used up. It is a complicated machine that is for sure
Calibrations were done at the park
Everything was also up-to-date And I do not have the Polar Pro app I will look into that
This is all very concerning because that particular drone never crashed and it never got wet. There are a lot of TFR’s and Geo fencing in my neighborhood which is annoying and I just bought an Evo as a back up
Good to hear. What did you do to get the drone back to normal? I have the exact same issue with the same symptoms. Thanks for letting me know.
I ended up sending the controller back again to Dji to figure it out . The controller kept showing a stick error on the right stick. I am still waiting for Dji to tell me what’s up. Meanwhile the Evo is a pretty good drone but it does not have the refined control that I Mavic two has.
samydraria
