Strange gimbal vibration and Mini not paring
Stellario
Sorry if this posts twice (I wasn't logged in initially)
My Mini's gimbal is malfunctioning with a fast vibration of the camera when I power it up, it also no longer pairs with the controller (I use an iPhone 11 with it).
I updated the Mini software and Fly apps last week, and tonight took the Mini up for a quick flight. Everything was normal, it took some time to connect to enough satellites and then asked me to calibrate the compass which I did successfully.
I used the auto take off for a change and had it hovering around 100' overhead while I adjusted the video settings, that is when it lost its connection. Moments later it executed a RTH and landed a bit harder then normal about 5' from its take off spot.
Since then I cannot get it to pair again after several reboots of it and the controller and battery changes. Every time I boot it up, it makes its start up beeps and goes through gimbal test movements and the rear LED blinks alternatively from green to red. The gimbal then quickly starts a constant slight vibration and when I pick it up and move it side to side or angle it up or down the camera angle remains fixed (no camera stabilization) and will not pair.
Any ideas on what this symptom is or how to clear this issue?
I happy to say I recently renewed my DJI care that I never had to use before.
Reactions: brsoft
I had a similar problem today, but the Mini just fell from about 3 m. :(
amazingnas
