Strange Lines on Pics
DomoDan
So, I recently intended to set the Mavic up to take both DNG and JPEG files...but set it to just DNG/RAW by mistake. At any rate, I open the pics up in Photoshop and every single one of them have 4 strange lines across the image. It looks like that section of the image is slide over to the right, and the void on the left side of the image is a pink tinted line.
Any idea what's going on here? Please see the attached screenshot. I'd love some input/guidance.
Thanks in advance.
Trying a different card is first step, it does look like an issue not writing fast enough.
Recording RAW stills is more demanding than 4K video.
Cards with inaccurate or misleading descriptions are common even on Amazon but you could get a refund better there.
Did I get an SD card that isn't up to snuff for the Mavic?
Try formatting your memory card in DJI GO. If that does not resolve the issue, then try a faster memory card (or use the memory card that came with your Mavic). The Ultra only writes at 15MB/s. You can find a list of memory cards that are known to work well here.
RTLflyer
