- Joined
- Jul 7, 2017
- Messages
- 869
- Reactions
- 917
- Age
- 54
I am looking outfitting a Mavic with a wired lighting system - does anyone know if it's possible to tap the front LED leads and route it to a lighting controller and some Strobons. Here's the specs on what the Strobons use for power. If it's even possible, I'm wondering how many lights it would support. Not too concerned if it shortens flight time, even if it's 5-7 minutes.
Any ideas and knowledge on this issue is welcome. For guys that have been doing DIY hobby stuff for a while: If this is a BAD idea, please say so.
STROBON v2 Navigation Light (BLUE) - Flytron
- Supply Voltage: 3.5 - 6 volt
- Current Consumption per hour @5V
Strobe: 60mA (1A when flashing)
Blink: 70mA (150ma ON)
Heartbeat: 120mA
Rolling Beacon : 170mA (1A when flashing)
Static: 140mA - Diameter: 21.5mm
- Height: 6mm
- Screw Holes: 1.5mm diameter & 18mm distance
- Weight: 1.50 gram without wires
- Wire Length: 30cm (only for "with wire" option)
