Techs - Gimbal motor removal help
DGfli
Perth, Australia
My Mavic 2 zoom crashed after a prop failure breaking the gimbal.
How do you remove the roll motor from yaw arm? It is glued in. Have tried heat and levering it out, but it doesn't budge.
Thanks!
I think the arms are cheap enough with the motors in that it makes more sense to replace the arm and motor. However, I believe you can replace the gimbal and not have to replace a perfectly working camera as well. I tried all the suggested places here, for my M2P gimbal problem and they all wanted me to replace the entire gimbal and camera assembly. Then I luckily found a place that will try to replace just the slightly bent or tweaked gimbal arm and save me more than half the money, since my camera works perfectly. He works on the zoom too, so if you need his info PM me.
KiKiHUN
