I have the ZOOM and I need to be educated.
What's the difference between HD Mode and Normal Mode?
What is Transmission Quality?
HD is probably 1080 and Normal is probably 720. the potential advantage or normal is you're using less bandwidth between the RC and the Drone for display the image, which could possibly give you more range or less potential for signal loss.I have the ZOOM and I need to be educated.
Use 4K if you can.I have the ZOOM and I need to be educated.
Its in the general settings in the go4 app. Click on the 3 dots top right corner then on the left click on HD, scroll down to Image Transmission Settings.I could be wrong, but I think both questions relate to OcySync transmission between remote and aircraft, not the video quality recorded to SD card.
Silverdragon, tell us where you're seeing those terms (marketing material, owners manual, or a pointer to the info), so we can pin point what you're asking about.
Chris
Yeah, those are image transmission settings between the remote and the aircraft. They don't affect your recorded video quality, The Normal vs. HD vs. Smooth settings are described on this page:Its in the general settings in the go4 app. Click on the 3 dots top right corner then on the left click on HD, scroll down to Image Transmission Settings.
