Tilted images with 9-image wide angle shot
AndersGB
Hi,
I tested the automatic "wide angle shot" in pano mode for the 24 mm lens and got a strange result. Four of the nine images were tilted about 45 degrees, see attached files? Has anyone experienced this? I tested it a couple of more times but got the same result every time.
I also took some "180 degrees" automatic panos for the 24 mm lens (21 photos) and they all looked fine.
I did some more research and found out that it is a software problem. I found this thread:
I will try that tomorrow.
LeoleoLeo
