Time-Lapse test with Mavic Mini
Roy Rogers
I did 2 time-lapse tests . With a full battery each time. I took off ascended up to 300 ft . Then just let it film .Both times i greater then 20 mins of footage .Both flights had high wind warnings but i could hear the motors from where i was and i hurd little variation in the sound they made.
First test it Yawed right then back to the left by the end . I had for gotten to calibrate before the flight and my last flight was 70 miles away and 2000 ft higher in elevation , up in the Tar Hills of the North Carolina Mountains.
Second test I did calibrate it and it stayed more or less perfectly still while filming cars, people, as a city goes about its chrismas day life.
In conclusion if I would had stopped after just one flight I would have thought the Mavic Mini Unusable for Time-Lapse filming ! The second Test did much better and I stop just short of calling it impressive only because at X 8 speed you can see even the smallest movement. I think the first test/flights yaw right and left again was due to not calibrating but I cant say for sure .
when the orientation display bottom center turns red and flashes, it means it is trying to get a GPS lock you will notice it more if you are indoors, but in your case you had lost GPS and it had gone into ATTI mode
Reactions: Roy Rogers
That doesn't sound quite right . it shows 17 satellites at the top . It has booted up in ATTI mode once before when I was deep in a valley with Steep Steep mountains on two sides . I thought it might have been referring to my cell phones GPS for the map ?
Thanks for trying to answer it though , Your the only one that's even tried .
Reactions: old man mavic
no worries that could be right about the device GPS though i know its to do with it trying to get a GPS lock ,it does it if i am at home and it is unable to lock onto enough sats to fly, if i am checking for any updates before going out to fly ,as i only use an ipad with wifi
now worries that could be right about the device GPS though i know its to do with it trying to get a GPS lock ,it does it if i am at home and it is unable to lock onto enough sats to fly, if i am checking for any updates before going out to fly ,as i only use an ipad with wifi
I would like to know what the limit is how many things can be using the satellites . when i first got into flying drones it would link to 19 , 20 , everytime almost everywhere . fast forward 2 years later 13- 15 is about all i seem to be able to link with .
Satellites just transmit info, you can have any number of GPS devices receiving the info
Liger210
