Time taken to charge 3 batteries?
QC uses the data lines to negotiate voltage with the device. I don't know how the negotiation works, but I had read it might be a small and specific resistance across the data lines.
So it seems the data cables are not supporting higher voltage, not the actual power cables, interesting I have to read about this. I was completely blown away, my old Blackberry cable supports 12V and the cable that came with fast charger did not, go figure :)
OK here's how QC works. It's based on applying 0.6v or 3.3v on the D+ and D- lines as if 0.6v is logic 0 and 3.3v is logic 1, and each of the data lines as a separate input.
Logic voltage is in reference to ground.
Thanks a lot, great link! I had no clue!
Why some of those cables do not work, technically this should work without a problem, D- is a white cable inside. It does not look like cable depended, but port dependent.
256 minutes Full 3 battery charge according to spec. I will leave this here! Please add to the thread if it took longer or less.
Just collecting Data from users.
Reactions: deepakvrao
It took me some time to find it. All the "how it works" sites would say what we already know: 9 or 12v is negotiated between device and charger. Yes, we know but HOW is it negotiated.
Now I have to set something up so my dad can use the powebank I gave him for Christmas 2 years ago to provide portable 9 and 12v.
The cable does have to pass through data connection from charger to device and not just power connection. Charge only ports and cables may have a resistor on the data pins to the device rather than passing the lines through.
Note that I found Samsungs may get stubborn going into fast charge, particularly if the charger is not Samsung brand. Just reboot the Samsung. There's also a setting available to turn off fast charging but not to disable charging altogether.
So it seems it is pretty much impossible to visually determine if the cable has a resistor that would block negotiation...I guess cheaper the better, I can see those resistors might be there as a feature to lock it only to 5V.
Hangar Drones
