- Joined
- Dec 9, 2016
- Messages
- 325
- Reactions
- 485
- Age
- 54
Getting really annoyed with the Mavic Air SD card slot? This might help?
Meh! I never take mine out and the onboard 8G gives you back up should you need it.. 64G card stays in and I just plug in the air to access both drives.Getting really annoyed with the Mavic Air SD card slot? This might help?
Easy.
But you do have to unfold the Air and power it on to get data out by cable, right? If I don't power it up I can't see the drive.
Don’t forget removing the gimbal protector...But you do have to unfold the Air and power it on to get data out by cable, right? If I don't power it up I can't see the drive.
I threw a set of these in my bag for this too.I bought a small pair of plastic tweezers and keep them in my flight case. Only needed to use them twice since I bought the Air but they work really well.
Meh! That's significantly more trouble than removing the card.Meh! I never take mine out and the onboard 8G gives you back up should you need it.. 64G card stays in and I just plug in the air to access both drives.
Easy.
Yes I too have a pair of tweezers and don,t get what all the fuss is about the card is no trouble with a pair of tweezersI bought a small pair of plastic tweezers and keep them in my flight case. Only needed to use them twice since I bought the Air but they work really well.
