My advice is
Take bracketed exposures and process as HDR. I always take bracketed exposures always. I don’t process them as HDR if it doesn’t end up needing it but it’s good to always have that option.
2) Get an xrite colorchecker. I have the xrite colorchecker passport and it’s great and portable but it’s a little small for such wide lenses on the drones. They make an 8.5x11 version that is actually less expensive and it would be easier to use if the size isn’t a problem.
X-Rite ColorChecker Classic
Amazon.com : X-Rite ColorChecker Classic (MSCCC) : Photo Studio Support Equipment : Camera & Photo
www.amazon.com
You take a raw photo of the colorchecker under the lighting you are shooting in and then run it through the software. The software will make you a preset you can use in Lightroom/Photoshop which will make your colors look the same under any lighting conditions. It makes a HUGE difference. You’ll never work without it once you start using it.
Those two things neutralize the effects of the differences in lighting as much as is possible. It does a dang good job.
