Top Mavic 2 accessories for April 2019 (by DDH)
msinger
DJI Drone Expert
Approved Vendor
Harrisburg, PA (US)
Site
mavichelp.com
I've compiled a list of the top Mavic 2 accessories for April 2019. These accessories were chosen based on their sales volume on Amazon over the past month. If you're looking for some new accessories to add to your kit, this list will give you an idea of what other Mavic 2 owners are buying and using.
SKYREAT Foldable Tablet/Phone Mount
Notable features:
  • Made of aviation aluminum-alloy
  • Able hold a mobile device between the width of 4-12 inches
  • Mount can be swiveled sideways to hold a phone
  • Hole at base to attach a lanyard
More details can be found here on Amazon.
Homga Landing Pad
Notable features:
  • 30 inches wide
  • Made of a waterproof nylon material
  • Includes stakes to ensure the landing pad stays in place
  • Fold up and store in the included storage bag
More details can be found here on Amazon or here in the DJI Store.
Threeking Parabolic Signal Booster
Notable features:
  • Boosts the remote controller signal to increase its range
  • Folds closed for storage
UZOPI Foldable Tablet/Phone Mount
Notable features:
  • Hole at base to attach the included lanyard
DJI Low-Noise Props
Notable features:
  • Created, designed, and extensively tested by DJI
  • Guaranteed to work well with your Mavic 2 since the props are an OEM DJI accessory
Fstop Labs Accessory Bundle
Notable features:
  • Protect the remote controller sticks & screen from damage when storing/transporting your remote controller
  • Extended landing gear will raise your Mavic 2 off the ground for extra clearance
  • Lens hood will shield the camera from the sun and help protect the camera
Fstop Labs Mavic 2 Pro ND Filters
Notable features:
  • Includes an ND4, ND8, and ND16 filter
  • Aircraft grade 6061 anodized aluminium frame
  • Sharp AGC glass made in Japan
  • Multi-coated to reduce ghosting, lens flare, and improve image quality
  • Sawtooth ridges on the sides make the filters easy to grip
  • Filters come in a padded, rigid carrying case
DJI Mavic 2 Battery
Notable features:
  • Guaranteed to work well with your Mavic 2 since the battery is an OEM DJI accessory
SanDisk 64GB Micro SD Memory Card
Notable features:
  • U3 memory card
  • Fast enough to record any type of photos/video produced by the Mavic 2
  • Plenty of storage space to capture all of the needed photos/video
  • Transfer files to/from the memory card with the included memory card reader
PGYTECH Prop Holder
Notable features:
  • Holds and protects the props during storage
  • Made of flexible silicone material
  • Easy to install and remove
DJI Prop Guard
Notable features:
  • Guaranteed to work well with your Mavic 2 since the guard is an OEM DJI accessory
DJI Mavic 2 Fly More Kit
Notable features:
  • Includes a full set of props, two batteries, power bank adapter, car charger, and battery charging hub
  • Guaranteed to work well with your Mavic 2 since they are OEM DJI accessories
PolarPro CrystalSky Mount
Notable features:
  • Securely mounts your CrystalSky to your Mavic 2 remote controller
  • Rigid frame design is over-engineered to eliminate any flexing while flying
  • Lightweight aluminum construction is built to endure your rugged adventures
  • Ergonomic grip is tapered to fit perfectly in your hands
SKYREAT Foldable Tablet/Phone Mount (New Design)
Notable features:
  • This upgraded version is more durable since the plastic tightening ring has been replace with a metal ring
  • Store the mount and lanyard in the included storage bag
SanDisk 128GB Micro SD Memory Card
Notable features:
  • U3 memory card
  • Transfer files to/from the memory card with the included USB 3.0 memory card reader
Smatree Mavic 2 Carrying Case
Notable features:
  • Made Of High-density EVA material
  • Tough and durable outer case
  • Carry with the adjustable shoulder strap or side carry handle
  • Can hold the Mavic, remote controller, 4 batteries, charger, and other small accessories
Fstop Labs Foldable Tablet Mount
Notable features:
  • Made of high impact ABS plastic
  • Attach and detach within seconds
  • 360 ball joint allows the tablet to be adjusted for better visibility
  • Folds into a compact form factor for storage
DACCKIT Carrying Case
Notable features:
  • Tough and durable outer shell
  • Can hold the Mavic, remote controller, 5 batteries, charger, charging hub, and other small accessories
Fstop Labs Parallel Battery Charger
Notable features:
  • Can charge 3 batteries simultaneously in 60 minutes
  • Able to also charge 2 USB devices
  • Comes with a 3 prong cable with ground
  • Charger is internally grounded for safety
  • Outer shell made of anodized aluminum alloy to help dissipate heat
Fstop Labs Carrying Case Set
Notable features:
  • Separate hardshell cases to protect the Mavic and remote controller
  • Water resistant exterior shell
Want to check out more Mavic 2 accessories? A commonly used list of Mavic 2 accessories sorted by category is available at MavicHelp.com.
First let me say I appreciate all your hard work and it’s interesting what folks buy.
However, I guess that the things purchased directly from manufacturers aren’t included. Perhaps the thread title or preamble should reflect this specifically. Just a thought
Things purchased directly from DJI? Right, I have no way of tracking those sales.
Please don’t misunderstand. The thread serves a great purpose. Definitely realize that tracking all sales from all vendors is an impossible task. Made my comment mostly to make the point that supporting innovators for our hobby directly is how I try to go... PolarPro is a prime example for me personally.
Fly on my friend!
The idea was not to create a thread that supports one's favorite vendors. Had more PolarPro products been purchased over the past month, then more PolarPro products would be in this list. I guess there's always next month... ;)
I would suggest adding to the title that this is thru Amazon only.
It shows different phone/tablet mounts but Amazon does not deal in Mavmount as well as some other mfg's and lots of folks here use Mavmount which skews the ballance a bit. There are other items like this as well.
I'm not saying its bad or wrong, you put alot of time and effort into things like this and they are very useful and much appreciated.
Keep up the great work and happy flying...
It would be interesting if we were able to capture the data to compare the SKYREAT sales to MavMount sales. At the much lower SKYREAT pricepoint, I'm thinking there is no chance MavMount is outselling them (even if a lot of folks here own a MavMount).
A landing pad is certainly not needed if you're able to find a flat, clean area to take off. That's not always possible, so these landing pads exist. And it must be a real problem because they sell like hot cakes month after month.
Reactions: LookToTheNorth
I would guess that Skyreat sells more because of the price difference. I was looking at theirs and thats when they came out with the updated one with the metal locknut. Wasn't that assuring to me. When I saw the quality of the MavMount and being able to use it in different positions, it was a no brainer for me. I have gotten burned by saving money too many times. Thats why I got PolarPro filters as you usually get what you pay for. I have seen pics from the cheaper ones and they do good for the money but still have too much color cast for my taste. I would rather pay more up front and save lots of time in post. But then if you think about it, DJI wants about $139.00 for a battery. Is the pack of filters really that expensive in comparison.
Sorry, got a little off track....
Ok I see the value of it now. Mabey I will make myself one
If you were closer, I would give you mine that came with the Fly More kit. I have never used it. If there isn't a good place to take off, I just do a hand takeoff and landing. I have never used the rth or auto landing stuff. Besides, only the landing pad or my iPad fit in the case at the same time so the iPad always wins as I can't fly without it.
I usually take off and land on the bed of my truck but I'm going to buy a waterproof flag from the dollar store for when I go hiking
To take off and land on......
I am OCD and I want the drone to stay as clean as possible. At takeoff and landing the props will kick up dirt, dust and particles. The pad also can provide a nice visual contrast for the vision system in precision landing. I always hand launch or use a landing pad,
GLobus55
