So my mm also has finally shown the auto altitude loss on its 70th flight. Can someone please help me understand why this happened.
After losing signal and autotriggering rth, the ac decided mid flight to start dropping altitude - look at the journey thru the checkpoints K/L/M/N. I hastily started pushing the thrust up and realised quickly that i should cancel rth first. Did that and was then able to get it to go up again. Rth altitude was set higher so that ain't it. There was no notification when it started losing altitude either. It's only after i cancel rth and try to pull it up when it shows the not enough power error.
1) why did it decide to start losing altitude
2) why the esc/not enough power errors on pulling it up (wind velocity was negligible - 6mph.
