V 01.04.0200
Airborne24
Refuses to download ,I keep getting the continue to download but the percentage line does not progress.
Try this, once download is commenced, switch your Mavic off, it’s not needed and will save your battery. Once the firmware has download you will get a pop up message to remind you to power up your mavic
It doesn't work l;ike that using the crapp, I tried it yesterday, turn mavic off, download stops.
you batteries in both your drone and controller have to be above 50%, make sure its no interference around the drone while its in progress. Personally i do mines straight from the phone, i only had a problem one time with it stopping, i turned everything off disconnected the phone and restarted everything, it started back from where it left off till completion
felixleo
