Video flicker
Makofire1
Part 107 Certified
Miami, Florida
I’m brand new to drones and videography and noticed that while playing back my video, there was a sort of flashing or flickering along some objects. I’m flying a M2P and shooting 4K, all auto. Is this normal? How can I prevent it or get rid of it? Different settings? Thanks in advance for your help!
Can you post the video so we can see what you're describing?
Try recording at a lower resolution. If that fixes it then your problem probably is...
• Display device video card insufficient
• Display program insufficient
• SD card insufficient (write speed too slow)
Those are the three most common causes of 4K video problems. By insufficient I mean under-powered or out of spec for 4K.
Reactions: CJH92474
I’ll give that a go...I don’t suspect the SD card is the issue, I got the fastest Sandisk sells. I’ll try watching the video on a different device. Thanks
sharpinjr
