- Joined
- Sep 11, 2018
- Messages
- 31
- Reactions
- 8
- Age
- 53
I went back to H.264 and haven’t had a problem. The problem with H.265 is that it is so processor intensive that a large portion of the computers cannot handle it.H.265 and card was compatible as shown in image above.
You Basically need a 1070 graffix card just to edit the 4k h.265 Its shocking dji has only given normal log in h.264 on the mavic 2I went back to H.264 and haven’t had a problem. The problem with H.265 is that it is so processor intensive that a large portion of the computers cannot handle it.
I don’t want to spend a bunch of time doing something and then send it to someone who doesn’t have the capability to view it smoothly so until that changes I’m sticking with H.264.
What graphics card you using the h.265 needs a very good card anything over a nvadia 1070 will do.This footage is recorded on the correct card and formatted before use. The computer used to process film footage is an i7 with 16 gig of ram. The computer did not make the footage skip it was imported directly to the computer hard drive. Any other suggestions of why the footage could be skipping so bad?
BDOG how do go about using the proxy option?
ts take a little while for the 4 K video to be associated with its counterpart lower resolution video during the first step
I think its been proven my unit was faulty prior to purchase.
U1 is about the same as class 10 so it won't work.Thats not how the onboard card should be capturing video. You have a Class 10 SD Card I assume from your comment. With the U3 specifier as noted in this picture. Or U1 will also work .
Try copying all of your important files to a backup location from the SD card and then perform a format of the card using the DJIGO4 application. Then take more video to determine if there is still skipping of the frames.View attachment 54967
You are correct. My oversight.U1 is about the same as class 10 so it won't work.
