Video Skipping
Could somebody please watch this video from around 40 seconds and then around the 1 minute mark explain if this is normal when recording on the MP2? card onboard was 4K compatible.
Cheers.
I was having this issue. After picking up a U3 micro sd, it's been silky smooth.
U1 is about the same as class 10 so it won't work.
my card id deffo u3 and it was formatted prior to use, and i am not a novice with tech and read up on the correct card before purchasing, so at least i got that bit right ;-)
Reactions: BD0G
You Basically need a 1070 graffix card just to edit the 4k h.265 Its shocking dji has only given normal log in h.264 on the mavic 2
What other companies even offer log.. at this class of UAS.
CMDR DV TEARDROP
