but other videos from my camera works good nikonSettings?
Most likely computer used for playback too old/not powerful enough to process the quality you captured.
Are you recording 4k ?? Try a 1080 as a test if you are then 720 then 2.7k and test.what causes video to slow down stop picture not moving fast ,,using mp4 ,my first footage was ok second ruined , should I use mov ? anybody had this problem
i believe you are right was set at very high resolution emptied my 64 card quickAre you recording 4k ?? Try a 1080 as a test if you are then 720 then 2.7k and test.
Settings?
i believe you are right was set at very high resolution emptied my 64 card quickDoesn't mean anything at all. Different cameras, different capabilities and requirements.
Again, what settings used on both....?
