Wakeboarding with the Mavic
scottief
Im trying to get shots of us water skiing or wake boarding. This is my 2nd attempt at doing this. My Mavic keeps losing signal around this one part of the lake, so I have to come back and wait for the boat to get into range. Let me know what you think. I have another one I need to edit which I am much lower and closer to the boat.
Cool shots! I just got my Mavic and plan to use it for wakeboarding...have you had better tracking with the "Follow Me" mode or Active Track?
Reactions: youngie123
Nice wide shots of the lakes near the end. Personally, I would get in lower and much closer to the action and use the Active Track modes to avoid the jerky kind of movement that's difficult to avoid using manual modes. then you can concentrate on framing the shot and let the Mavic do the flying!
Have Fun & keep an eye on that Battery while you're over the water ;)
Like mentioned above, get closer to the action. And work on getting shots with no tilt or yaw movement. And when you edit your clips together, rem0ve any of those aircraft movements as they do not make for good viewing.
Thanks for sharing.
PJ19
