Wall Printing Drone
roineust
Tel-Aviv
Is it possible to build the following drone, based on a DJI platform, what DJI model would that be?
  • Wow
Reactions: Gindra
X8 platform in the video. I’ve not seen a DJI product with an x8 frame. The frame and motor setup isn’t that difficult to build. Probably can be ordered off the net. The rest of that, ???? More work than I would want to be wrapped around.
Were you a part of this original concept?
Reactions: roineust
Yes, most of it is my work.
The development part that was more focused on printing functionality, was done by building the following module and then adapting it to work with the drone:
Besides that, there was also an earlier version, using spray, that actually flew to the wall:
And other versions, that went higher and bigger (using spray rather than ink-jet):
From what I see, you want this unit to be able to print on something not accessible from a ladder?
In the video, it has something the unit bumps up against to hold position.
That will be a tricky task to accommodate out in the field.
Reactions: roineust
Leonardo da Vinci would probably have a heart attack while watching that print in ten minutes what would take him weeks!
  • Haha
Reactions: AMann and roineust
The drone drives against the wall, all 4 wheels are in full contact with the wall.
Printing at ink-jet resolutions (15-2000 DPI) is extremely hard if not impossible to accomplish, just by hovering near the wall, there is a need to physically lean against the wall.
This is the best resolution that can be achieved with current technology, for printing without leaning against the wall:
And more from the same group, this time for another artist:
Another possible application for wall printing drones, are billboard advertisements:
I played around with making a large frame to mount an Arduino controlled sprayer to make large wall murals once. The drones fitted with ultrasonic wall distance sensors are good idea, However I would’ve tethered them for power and possibly even paint. I wonder if they are using a camera with the base computer to control their position on the wall? It would be fairly easy to do, and one can use a IR beacon on each drone for the camera to precisely detect their position on the painting.
Reactions: roineust
He was an inventor so maybe not.
You are right, see my avatar? Leonardo's secret drone drawings were centuries ahead of his time! ;) Even Michelangelo would have used drones to paint the ceilings of the Sistine Chapel had he been given the chance!
Actually it’s in its infancy but this technology will be really a big step for mural artists. One day, Banksy might even do it...
Reactions: roineust
merycs
